Hi all i'm after more advice!!!! The water in my header tank keeps boiling
All the rads have TRV's with 15mm copper, There is a rad in the garage (K1 1200 X 600) I'm going to remove the trv and replace with a normal valve . Hopefully this way i will not need a pressure relief valve????
Also there is no vent pipe i plan to put one in not sure where? I have put a pic below and coloured the pipes!! Can i put the vent pipe in the horizontal part of the feed pipe? Ignore the wiring that has now gone never liked the wiring center being on the floor next to the cylinder!
The red one is just a bit higher than the cylinder and has a bleed valve on the end.
Blue is the feed from the header tank
orange is return
orange is return
