my boiler does not make water hot!!
30 Jan 2010
Hull
i have new installed boiler since last year but recently does not make fire to make hot water and sometimes water is just warm. any suggestion?
well, yes i am thinking about it but it is not under warranty at the moment after this one year because it is present :D from landlord. i am not sure they will accept it or not!! :D
it has 24 month warranty 12, months gone, it is Sime Ecomfort 25 HE
so what can i do just topping up!!
if you know it, please tell me how
thanks
If the pressure on the pressure gauge is between 1 to 1.5bar, then all is well. If the pressure is reading zero, then under the boiler is a metal flexi pipe about 8" long. There are 2 valves with a black handles, connected to this hose. turn one on, then the other you will hear water going thru the pipes, as soon as the pressure is between 1 - 1.5bar TURN OFF THE VALVES.
it is just one yellow and one black handle. pressure is 1.1
Don't touch the Yellow - that is gas. On the valve with the black handle, is that connected to the flexi hose, with a long chrome connector about 4" long connected at the other end.
