Sliding wardrobe doors
How about.
I have looked at the specification and installation instructions for the doors that you posted and they seem identical to doorsdirect. However I have never fitted techglide but as a lot of companies use the same components I would probably go for the cheaper option.
Happy now.
the cheaper option is not always the better one. unless people have experience of using / fitting all them.
If you have 2 identical products and one is cheaper than the other, would you buy the more expensive one?
I have fitted sliding wardrobe doors from a number of different suppliers and there isn't much difference between them in quality or method of fitting. If you could pass on some of your obviously vast knowledge why don't you?
as you have never fitted them how can you tell the quality. you are only guessing.
What is your background geraint? How many sliding wardrobe doors have you fitted? Are you even a tradesman?
I've got a Fiat Scudo so I don't need to drive a Peugeot Expert or a Citroen Dispatch to know they are the same.
As I said I have looked through your past posts and all you bring to the party are petty critisisms and snide remarks.
You cannot bring any useful information into the discussion because you don't posses any.
Every bottom roller sliding door I have fitted has been identical in quality, style and method of fitting.
Now trot off and tell the builders about insulation.
