Hi Ollski
Could you explain what you mean by 'pcb' please.
Attland
Attland
1) Is a boiler engineer likely to be any better than a Gas Safety registered plumber in carrying out a diagnostic check?
Thanks to all who have contributed to my dhw problem.
I have reached the stage where my plumber suggests a diverter valve replacement for which he will charge £145. We used the check on the heating pipe below the boiler to reach this conclusion. I note however that AcidTechno had a similar problem and described on another thread that neither a new diverter nor heat exchanger solved it.
The fact that ollski suggests that I might need a new pcb causes me to hesitate before proceding with further work until I'm sure of it's value.
So a couple more questions please.
2) To AcidTech regarding his similar problem. Have you solved it yet?
Finally an answer to tdesnos who asked if my problem started after the diaphram change. Not exactly. Before it we could get no dhw whereas now we get some for a while.
Not yet. I've bought a thermister on ebay, will have a go at fitting it and report back.
Water thermistor is on the brass divertor, heating is on the copper flowThanks for the warning. How do I tell the difference?
Hi Attland. Have you managed to solve the problem yet with the new Thermister? I have the same problem on my boiler and my uncles both baxi 105e's.. Be interesting to find out the solution.. Cheers and fingers crossed for yah....
