heating stays on
15 Oct 2003
hello I need help.
our room thermostat is being over ridden by our h/w thermostat. h/w & c/h work ok independantly. but when the room stat is on and the h/w stat comes on then the c/h will not go off until the h/w stat turns off.the 3 way valve motor is working. thanks in advance!!
ARe you sure the three port valve is working as the symptons you have describe scream that it aint
I cant think of anything else that ill cause this problem?
SOunds more like it's wired wrongly?
Just before I go away for 3 weeks, I've just noticed that my own HW is getting up to boiler temp which it shouldn't!. 3 port valve is letting by to HW when on c heating. So it could be the head mechanism or the wet bits of the valve, right? Thought I'd take the top off the 3 port to move the shaft round to ch-only while we're away. For some reason one of the screws is seized in, so I had to push to hold the screwdriver in the slot. I couldn't get the screw out anyway, but the pushing has made the top plate of the valve leak. No time to change the valve - pipes will need cutting to get it out. So I've had to drain some water out, and will be coming back to a cold house.
Maybe I should have got a man in?
Give a key Chris and I will pop around and sort it for you, you can do the same when i finally get a holiday :lol: :lol: :lol: :lol: :lol: :lol: :lol:
BUMMER mate
