Whats directly on the other side of the wall behind the blank plate in the bathroom?
Then don't reply to topics where you can't be bothered to do a proper jobGet lost I cant be bothered to read 3 pages of rubbish and p**s taking
Where's the logic and consistency in that given that in a recent topic all were agreed that BS 7671 does not require existing installations to be brought up to the current standard, and that it was even permissible to replace a CU when the lighting circuit had no cpc? A position which is endorsed by the ESC.In addition installation will need to be brought up to 17th edition requirements.
blank plate with notches and even a knockout in the centre should you wish to use it. (not MK)Usually not - they are just plain bits of plastic.don't blank plates usually come prepared with notches that can be removed for allowing a flex through?
Some flex outlet plates are like that, e.g. MK K1090IMO, probably better suited than a Flex outlet plate as the cable comes from the bottom, not the middle
Or a manufacturer saving costs by selling just the faceplate part of a flex outlet on its own, to be used purely as a blanking plate?blank plate with notches and even a knockout in the centre should you wish to use it.
possible, but i don't think so. There doesn't appear to be any provision in the moulding for any other parts to be attachedOr a manufacturer saving costs by selling just the faceplate part of a flex outlet on its own, to be used purely as a blanking plate?blank plate with notches and even a knockout in the centre should you wish to use it.
Get lost I cant be bothered to read 3 pages ....
Which regulation says that?Direct like for like replacements are permissable in a special location
Which regulation says that?but changing a blanking plate for an FCU is not like for like and therefore this part of the installation would require upgrading to 17th edition.
Where's the logic and consistency in wanting to add RCD protection to the bathroom to bring that part of the installation up to the 17th given that in a recent topic all were agreed that you can replace a CU when the lighting circuit had no cpc without bringing that part of the installation up to the 17th?I was not saying the entire installation had to be upgraded.
