leaking radiator
23 Apr 2006
Glasgow
Hi
I have a leaking radiator. This is a radiator which was purchased and fitted by cowboy builders. I don't know what the quality is like. At first it was leaking at the pipe, so I put tape round it and stopped that leak. It is now leaking from the bottom of the radiator where the valve is screwed in. I have tried tape but it still leaks. It leaks when the pressure for the system is correct and the heating is off. When the heating is on the leak disappears.
Is it possible that there is a crack in the radiator? Do you think a new radiator is the answer. I have tried to cure this for over a year.
have you disconnected the valve body from the rad
where have you put the tape on the valve and what tape did you use??
Have you tried loctite 55 instead of PTFE? I take it that you do actually remove the nut from the radiator before you apply the PTFE?
Chances are that the heat evaporates the water as it leaks, and it doesn't actually "disappear"
Yes I have removed the valve and I haven't tried loctite 55. I have used PTFE tape. I will try the loctite and see how I get on.
loctite has changed my life - used to use gas ptfe and smear jointing compound. Now works fine with a few turns of this stuff (feels like dental floss). Couple of quid from screwfix amongst other places.
Hemp and boss white still rules my life- I`m addicted to the smell :shock:
