triton spellbind shower LP issues
30 Mar 2010
Hampshire
I have the above shower and it worked fine until I moved my bathroom about. It now cuts out and flashes LP whenever I turn it on. However when I turn it on without the cover on it works fine so I don't think its becuase of the low water pressure.
Could it be short circuiting?
Any help appreciated
Nick
sounds more like you have a bad connection.
check the 14 pin plug on the pcb and also any connections around the solenoid valve and tco.
turn the shower power off make sure the plug is in firm on the board.
and just general check the wires are tight on the tco etc.
also check the bottom of the solenoid valve is a thin clear tube
check that don't kink when you place the cover on.
tried that an there is nothing obvious. When I turn it on and LP flashes i swear something on the circut board flashes quickly as well. May it be worth getting another cable for it?
DOnt thin its that as it happens when the cover is plugged in but is not on the main shower bit if you get me???!!!??
i thought you said it happens only when the cover is on and not when removed. ?
also check the lead from the pressure switch at the bottom of the shower
where it connects to the pcb.
If i plug the cover to the main shower it cuts out, even if they are not screwed together. If I dont plug the cover into the main shower the water comes out fine and powerful. Therefore my assumption is its eiter the cable connecting them both or a PCB problem on the cover.
Sound about right??
ok
if you remove the 14 pin plug how are you turning the shower on
as the on/off button is on the cover and you have disconnected it ?
sounds like your only putting it through commissioning mode when you don't connect the 14 pin cable..
no not if you had the shower in use before.
have you checked both the inlet filters ?
