Triton LP Thermostatic Mixer Shower
29 Oct 2008
Cardiff
Hi Everbody
I have Triton LP Thermostatic Mixer Shower which was working fine. Suddenly it starts giving cold water either I turn it to full hot
Any help please
Hi Friend
Thanks for the prompt response. The only pipe I can see is outlet pipe after the mixing knob. Unsure whether the water is cold or hot in the hot pipe for mixer. However other than this mixer, the other taps are giving as usual hot water
Thanks :D
may be a seized thermostatic cartridge.
how longs it been installed has it been ok ?
does the flow reduce when turned to fully hot at all ?
Hello again
Friend, I will try to answer as much as I can.
DO NOT KNOW ABOUT THIS CARTRIDGE. Where it can be found. Either in the mixer knob or inside the loft and how to replace it
we bought this house 6 months back. This house was built in 2001. I can assume that mixer was installed at the same time. Since 6 months no problem with the mixer. It just started yesterday
There is no flow problem at all. All is that no hot water, even you turn the mixer knob to full hot
Many Thanks
you really need to check the hot feed to the mixer to see if its getting hot .
as it could be just a blocked filter etc.
can you not locate it at the cylinder end ?
Many many thanks
I will try and let you know shortly
Have a nice Christmas and happy New year
:D :D :D
I found cartridge needs to be replaced. The cartridge has broken part that shift the mixer knob
