triton spellbind shower LP issues
one is bottom left the scale trap the other is where the mains water pipe joins the shower gauze filter inside.
you made sure any iso valves etc are fully open.
is the display red aswell as displaying LP. ?
should turn red and
‘LP’ and ’LOW PRESSURE’
flash alternately
when the water stops have you pressed the start/stop button
once to reset the shower. The shower will shut down and then
begin its start up routine.
does it go back to LP.
if so i would check the inlet filter.
should turn red and
flash alternately
Spot on. Did you invent this shower????
IF so where is the inlet filter and what problems should I look for in it?
remove the mains water inlet pipe and in the end of the plastic pipe
should be a plastic gauze filter.
look for scale or crud if you say you have moved the shower etc.
turning the water on off can free crud in the mains water pipe.
you say you have checked the scale trap on the bottom left of shower.
yeah i cleaned the filter on the bottom left and it was full of scale.
Ill try the other filter tomorrow and let you know if it helps
Thanks for your help. I was complely stuck beofre this
and you've double checked the pressure switch at the bottom is making the m/switch ?
the thin clear tube below the solenoid valve follow the tube to the bottom and it joins the pressure switch.
on that pressure switch is a micro switch, when shower on is the m/switch being pushed in (activated)
