Hi there, I have had a problem with my central heating over the past couple of days. Problem being I had hot water but no heating. After a few hours scouring google etc. i come to the conclusion that my problem was with the 3 port valve. the make is a salus 322 and up until 10 minutes ago i thought i had the problem solved. Let me explain. The manual switch according to spec sheet on Salus website states it is for draining down, not sure how to do that or even if i need to but hey there you go.
After reading some of the similar problems peeps have with 3 port valves on this forum i discovered that this actual manual switch thingy opens up both HW and CH. wasnt sure if i needed both CH and HW switched on digital thing but tried my luck anyway. low and behold, problem solved and boiler fired up and we could all creep out of our sleeping bags as the rads warmed up.............. for about 10 minutes. Then it all packed up. No boiler, no nothing. Anyways, to cut a long story short. When the manual lever is lifted to position nothing happens, but if i sit in my airing cupboard and hold this manual switch lever up a tad more with my finger the boiler fires up and i can feel the hot water running through both sides ( HW & CH). Im not a donut and i think its safe for me to presume i need a new actuator for the bloody thing, But has anybody got a quick fix or a remedy for this evening, cant spend another night with 6 in a bed to keep warm.
Thanks in advance.
Zig
Thanks in advance.
Zig
