Except that X400 takes four weeks and X800 about 2-4 hours.
However, if the pump is not turning at all then there will be no circulation of the chemical!
If the pump is stuck it makes a buzzing sound when listened to with a stick or if its turning it makes a rumbling sound.
Removing the end screw should enable the shaft inside to be seen if its rotating.
The shaft on a Grunfoss does not have well defined slot but rather like a well worn slot. That can be twisted to an extent. They say its for safety but the other pump makers dont have an issue with a nice slot.
Tony
Tony
