Soak-away query?
2 Feb 2006
Staffordshire
When building a soak away at the front of a building, i.e. a frontage that is accessed from the road/street/carriageway/public highway, what is the minimum distance the soak-away needs to be from the road?
Also, does the measurement apply to the footpath?
The reason i ask is, a b.c.o. once reminded me that i was close to the bone when installing a rear elevation soak-away at a corner plot property.
Can't remember the distance though.
Probably 6m....?
I have looked at an old post of mine and i said 6m. Can anyone confirm?
5m Nose its the same as a building :wink: AD part H /3
Dont think footpath comes into it, measure from road.
Yep H/3 para 3.25a just checked.
I don't think there is a minimum distance per se I think it depends on the local ground conditions. The soakaway bible http://www.forestofdeanpartnership....roved documents/BRE_Soakaway_Design_Guide.pdf mentions something like that too. I know that form housing schemes road soakaways can be located in the verge but I guess they're likely to have engineering input.
That didn't really answer your question did it. :roll:
Cheers guys!
I have been wondering how folks are getting around having to install soakaways in frontages when installing impervious paving, tarmac etc.
A lot of properties can not accommodate a soakaway that is both 5m from the building AND be 5m from the road.
Just to clarify - Is the soakaway for surface water or foul water?
If it is for surface it is 5 metres, if for foul then it is 15 metres from a building, 2 metres from a boundary.
You can download the relevant Building Regs from a
sewage treatment website. Click on Useful Links and then on Sewage Treatment Section H2 Building Regs which also incorporates H3.
