Problem declared unsolvable by Icgs (at least without megabodge such as gluing it in and putting rubber tape around it) due to incorrect equipment This is for a porcelain sink not sanitaryware.
View media item 22123
How do you fit this push fit waste I have dismantled here? Like a genius I paid no attention to how it was put together while still packed.
As you can see it contains:
Push button
Tail buton pushes into
Two silicone gaskets
A plastic disc the size of the tail
A back washer.
I tried for an hour, then noticed it was daylight and I'm throwing in the towel for today. Did manage to fit it, but there is two curved rectanfular holes in the side of the tail the button pushes into which I assume must somehow be sealed with one of the gaskets (the other one probably being what the button pushes into). Anyways, water came out of the holes so I blew it.
What is it I should have done?
Push button
A back washer.
