I need to do a job changing a consumer unit in a property which has an ancient GEC mains cut out box. It is a large metal box with a door on the front and a lever at the side which cuts off the power when it is pulled down (and also unclamps the unit door). Inside the door is the main fuse and a couple of connectors at the top where the main tails from the meter are connected to the main tails that go from the cut out box to the c/u - This connection is broken when the lever at the side of the cut-out box is pulled down (the lever controls some 'forks' which are inserted/removed from the connector blocks when the lever is pulled up or down).
I am replacing the old main tails from the cut out box to the c/u which obviously need uprating however, one of the terminal screws in the old GEC cut-out box was cross threaded when the old tails were initially installed and I was unable to remove it without the whole connector breaking (the mains supply comes into the cut-out box, out to the meter, then back into the cut-out box from the meter and out to the c/u)!
Needless to say, its not a type of cut-out box I've worked on before! Would it be possible to get spares for such an old piece of equipment or should I be calling the REC to sort this out? I believe the home owner inquired as to the REC changing the cut-out box completely several years ago (on noticing how ancient it was), but they were uninterested at that time.
Any advice at all on how I can get this issue sorted would be very much appreciated.
