Hot Water flow control on Worcester 240
28 Apr 2010
Avon
I have a Worcester 240 and I want to adjust the hot water flow control (to speed or slow the flow sacrificing temperature of course), the manuals I have (trade and retail) don't explain its location although do mention it - can someone help me locate it?
I believe the hot water flow control is on the diverter valve.
The Worcester 240 has the same sort of diverter valve as the Potterton Lynx Electronic so the diagram below may help you.
Cheers.
Cheers.
Many thanks for your help, I'll have a look a bit later! :D
Is this the one with a green lever underneath the boiler on the right hand side, with summer/winter on it? This is basically flow adjustment.
No green lever on mine I don't think?
This isn't mine, but this is what it looks like on the outside.
It's fitted on the cold-mains isolation cock under the boiler, maybe yours doesn't have one though. It'd say in the manual if it does.
The manual does mention it, refer to it infact but doesn't point out it's location but I'll check hopefully today if the diagram above helps out!
