Hi, having recently moved home, we find we have a upvc door that requires the handle to be lifted and then the key turned to lock the door, from BOTH sides.
Now I have a few issues with this type of lock and would like to replace it with something more practical and similar to the YALE / Mortice / Deadbolt solution in my previous home's wooden door.
I would like a door that would latch shut (with over-ride) so it can't be opened from outside without a key, further to fully secure the door (multipoint locking), one would need a key from the outside, but only a lever or handle from the inside. Is such a lock available? where would I find it? and would it be easy to fit.
My reasons for this are as follows.
If the door is locked from the inside and the key not removed, then the next person wanting entry cannot use their key.
If the key is removed and accidently misplaced, then the door cannot be opened until the key is found. Generally this is nothing more than an inconvenience, but if there was a fire, having a route of escape rendered unusable by the loss of a key could prove fatal!
Any ideas?
Farrukh
Any ideas?
Farrukh
