I'm in the process of converting my garage and am at the point of insulating and the electrical first fix. The ceiling is to be insulated with PUR board within and below the rafters and the floor is to be a floating PUR and chip board affair.
As both the the floor and ceiling are to be fully insulated, then where can the the lighting and socket ring main cables run?
Having trawled through the similar subject posts I've concluded that the lighting cables should be ok within the insulated ceiling and that the socket ring main could run horizontally around the room, burried behind the dry lining, above the floating floor insulation (perhaps in conduit)?
Does this sound reasonable or is there a better solution?
Thanks,
Andy
Thanks,
Andy
