Hi all
following in from my previous post
http://www.diynot.com/forums/viewtopic.php?t=225975
I waited patiently and then some more ( over a week) and sanded down the (white)undercoat lightly with p1000 wet and dry.
I have applied the 1st coat of the satin paint using the following method ( which i use for gloss) :
apply with a small gloss roller and gently brush out the (orange peel) with a 1" brush.
Now the problems i have are:
the paint coverage was really bad and looked really patchy and the brush marks look horrible.
in a fit of frustration ( and desperation) I applied a second coat via the roller and brushed it out again.
Now bearing in mind that the tin says it needs two coats only and its (sort of) had two coats it still looks patchy.
I am thinking that a light sanding should get rid of the current brush marks but would really appreciate som advice oon how to get a good result.
thinking I may have to go to gloss !!
Thanks very much in advance
