peugeot 307 cd player code lost
19 Mar 2007
hi - anyone can help me to find the security 4 digit code for my peugeot 307 hdi clarion cd player ?
found this from google.
There may be 2 different codes depending on how old the car /radio is.
Try 3963
and if your radio will not accept any digits higher than 6 ( ie 6666 is the highest )
then try 2211
failing that you will need to get your serial No, and use google to find an unlocker, or take it down to an electrical specialist.
if you google peugeot 307 radio code, the first result is a site I have used a couple of times for other cars, and its been ok.
Try 3963
then try 2211
thanks mate, its my 2004 peugeot 307 1.6hdi, the unit in there is a single cd unit model no clarion pu-2471a(j).......i havnt actually removed the unit from the car yet because i want to open up the unit and remove a cd that appears to be stuck inside....ive also read somewhere that the unit is coded to only work with my car, so am i right in thinking that if i did remove the unit, take out the stuck cd and put it back..i wont need to enter any code ???
