Have got 2 lights in hall coming off a multi terminal junction box.
The switch is 1 gang 1 way also coming from that junction box.
I want to add a 3rd porch light cable into the junction box and put a 2 gang switch wired from the junction box with a 3 core wire so the 3 core will operate the 2 gangs 1 way. 1 gang for hall lights and 1 gang for new porch light.
However when I came to do this having run my new cable for porch light up to the junction box I realised that the new cable seems ever so slightly thinner than the other light cables.
I assume that either the other light cable is a different brand or it is 1.5mm and I have 1.0mm.
Is it safe if I have a smaller cable size in this situation or should I change it to 1.5mm (if that is what the existing cable size is)??
How can I tell the old cable sizing ( Crompton cables 300/500V) and if it is 1.0mm or if it is 1.5mm.
All lights in house are fed from 3 multi terminal boxes (approx 6 lights on each) into which the main feed arrives and all switch cables and light cables connect and fan out from there (the feed does not continue on to another JB)
New cable is copper cable company BS 6004H I.S.201 1.0mm
