Retrofitting lateral restraint ties and binders
10 Jun 2010
Carmarthenshire
I am looking to improve the wind bracing and lateral restraint of a 1960s traditional rafter and purlin roof. I know in new construction the return length of the tie would act mid block on the cavity side of the inner course.
What options are there when retrofitting these?
Is simply bolting to inner face of blockwork sufficient?
Similarly I wish to place a 200x75mm to span over ceiling joists between loadbearing walls to reduce possible deflections as I use the loft for some additional storage.
Should the fixing of beam to joists be a coach bolt or is there a bracket/strap alternative.
I'm not a roofer or builder, so take that into account when considering any advice I give here..
there are straps available that are flat and take a quarter turn halfway along it. I think that these are for securing top plates to walls though, but would serve the purpouse you want..
High GW,
Facing very similar issues to you. In addition, almost 20 years ago, some idiot of a plumber put five 3/4" holes in the space of just 12" along one of the 4"x2" "binders" (binders? :lol:) so, like you, I am looking to upgrade the bracing / binding / hanging of joists. Did you settle on a solution for connecting the reinforcing binders with the existing joists and if so, would you mind sharing it? Cheers.
