how to wire ADE reson8 bell to galaxy 18 ?
you connect it this way;
12volt + from panel to bell box + hold off
0volt from panel _ loop thru the PCB T connection (lower connection
(just below the speaker symbol on right hand side of PCB)
connect to - hold off on bell box
tamper return from bell box to the other side of the loop (top connection)
R101 (1)right hand side of PCB connect to bell trigger on bell box
R101 (2) right hand side of PCB connect to strobe trigger on bell box
loop a 0v supply to R101 to middle connection
the strobe trigger relay is as you can see a normally open connection using three connections, the closer one to R100 is the strobe output, the middle one is the 0v supply and you dont use the third one!
if you get any problems post again
as long as you have not changed any settings on the output section of the programming section, you should be ok
John
John
You my friend r a star thank you very much. :D
