Fireplace Help!
Status
Not open for further replies.
22 Jul 2007
Devon
Evening Folks,
1st post so be gentle!!
We have removed an awful gas fire (well the Gas Safe fitter did)from our living room and knocked out brick fireplace to reveal this opening!
I had planned to fit a cast iron insert, but it doesn't quite fit into the insert, around a 2" gap between wall and edge of the insert...
Any suggestions? Another though we had was to open it out, but I'm not sure, there is a lintel underneath the arch bricks, if that is removed won't it make the chimney breast unsafe?
Thanks in advance for suggestions & comments!
You have an old bit of steel someone has stuck in, a course of brick laid on edge Above that you should have a 50x10mm cambered chimney arch support bar, supporting the soldier course cambered arch.
Every thing below the camber arch bar, you can pull out, including the 2 half brick skins each side.
Build your new opening to size required, slip prestressed concrete lintel over new opening if required.
If you intend to burn coal, back fill behind insert with lean mix vermiculite and smoke test flue.
old un.
Thanks for that! The odd bit of steel was actually a very old gate hinge!! I would of been surprised, but the previous owners had done shocking things previously, this being the latest one we've found!!
We now have a nice size opening, ready to be used!
Evening Folks,
Hi, what did you do about the gap - we have same issue.
Please do not resurrect old threads. See the forum rules. ONE new thread will do.
Mod
Status
