I've been reading this section of the forums for some time, and find it very interesting and informative. Now i've found it's time to register, and ask for some advice myself. So here goes...
My home office only has a single switched socket outlet (on the house's ring circuit) and has my desk electrics plugged into it as shown below...
Dispite there being 6 outlets (at the top of diagram), only the UPS is plugged in here. All my equipment is plugged into the 4-way and 8-way extension leads (bottom right of diagram).
The total load, measured at the black plug using a Maplin L61AQ Plug-in Energy Meter, when everthing is switched on (which is possible during normal working) is averaging at 2.3 to 2.4 amps. I cannot measure the exact peak value, but i've never seen it hit 3 amps.
My current plan is to replace the extension leads with proper surface mounted socket outlets.
Questions...
1) Would it be best to wire these with 13A flex or 2.5mm T&E ?
2) Would a 5 amp fuse be best for the main feed plug?
3) The spotlight is made of metal, but only has a 2-core flex. Should this be replaced with 3-core to provide an earth?
4) If i want to replace the switch that is connected to the UPS output, for one with more gangs, would this be acceptable?
Questions...
