The SITE versions are significantly cheaper than the Makita branded tools and Screwfix are claiming they are the "same product, different colour" anyone know if the batteries are interchangeable?
most manufacturers when the bring out a budget range down scale on things like lower ah batts plastic gear boxes but often use the same moulds to save costs so
although the batteries may look the same they are unlikly to fit as they may contain inferiour batteries
having said all that the componets could be identical but different colours
you realy need to take your tool to a retailer who will let you try
and be warned iff you can make the battery fit by a bit off tinkering with the ribs around the batteries dont expect your charger to work on it but it might
