I have an old Electrolux Hoover which has packed up.
The culprit seems to be some sort of 4 wire capacitor(?), one wire has disconnected from it. The motor is rated at 450w if it makes any difference.
The supply in connects to the capacitor with two wires (red & black) via the on/off switch and another two wires (also red & black) come out at the other end. They in turn disappear off to the windings/brushes.
Does anyone know if this is a capacitor and if so is it just there to reduce interference or is it required to make the motor start/run? Any ideas where I could buy one. Failing that, if it is only there for interference can I just bypass it, it is used so seldom that the interference would not be an issue.
Many thanks for any input.
this
