Sash Window problem
27 Jul 2010
London
Hello,
I've been renovating sash windows in my flat for the past few months, all going well so far.
However, in the kitchen, instead of the sash window frame sitting on top of the concrete window cill, this one has the window set into concrete cill by about 4". So whats happening is that water is seeping in between the concrete cill and the bottom of the sash window causing rott. From the inside the arcitraving joints are cracking open at the bottom of the window.
I'm going to remove and replace the acritraving, but any ideas of how to stop the water seeping in in first place?
Pete
sorry no I havn't however I am in the process of restoring some sashes too, can you offer any tips? Things I'm struggling with specifically are removing old screws from the pullys, and removing the paint, seems to take forever!!
I've come across this many times in older buildings and it really is bad design in my books.
Their are a number of methods that can help.
You could always remove the timber cill completly and replace with stone or sand and cement
but if that's not an option then all you can do is to treat and seal with a mastic, I've used polysulfides in the past which are good and last well and recently have used the same stuff that's used for flashings , leadmate or similiar which is designed to be flexible.
Hello,
Pete
Hi Pete,
It would be good if you could upload a photo or two as it’s a bit hard to give sound advice without seeing the window.
If you replace the wooden sill it should replaced with another wooden sill (and the lower sections of pulley stiles and out linings also would need to be replaced, using the same species of timber if possible, ensuring the same moisture content between the old and the new timber. A typical softwood being Douglas fir and A typical hardwood being oak) as the structural joint between the pulley stiles, outer lining, inner linings would be lost and using any other material would only cause further rot and decay to the timber members.
Really glad to hear you’re repairing your sash windows rather than replacing them....
