HELP Is My House Going to Fall Down??
Are there any cracks in the first floor ceiling under the loft joists?
Which way do the loft joists span (front wall - back wall or party wall - party wall)?
How wide is the crack in the party wall?
Is the crack larger at the top or bottom?
Does it continue to upper floor wall?
Have any large trees local to the properties.. especially ones removed?
What soil is under the foundations?
Photos would help
I don't think i would be able to tell a although the ceiling joists are there the ceiling isn't - all the rooms have false ceilings.
The joists span from front to back wall (these are the ones that would hold the ceiling). There are other joists which go from one party wall to the other.
It's quite difficult to say as the wall is in poor condition anyway but with the plaster on it was only a milimeter or so, with the plaster off it looks wider.
From what i can see yes.
Yes top to bottom of the whole party wall.
None on my property however, nextdoor (the end terrace) has a narrow cobbled road to the side of it and directly accross are large trees which span the height of the house. None have been removed but yes i've wondered whether these have contributed to this.
I honestly can't remember and would need to dig out our survey report.
Photos would help
I'd need to take some tonight when i'm home from work. Sorry if my reply is lacking technical detail, i'm absolutely clueless about building work :oops:
Right well the loft storage stuff wouldnt contribute to a crack in the party wall as the span is in a different direction.. worst would happen is the front/rear wall starts bowing out at the eaves level or the roof starts to sag..
So long as your relatives werent storing masses of books or having parties in the loft i wouldnt worry too much..
Trees sound like a fairly strong possibly cause for the crack.. but could be something else (ie burst water main etc)
If you cant get your hand in the crack then there is very very little change the house will fall down around your ears.. a couple of millimeters is nothing too major and may not even be a structural issue..
Get some photos done.. the trees at the end (long wide shot) would help..
Then figure out if your house is built on clay, chalk, peat, sand etc..
