Yesterday I fitted a 12V Manrose bathroom fan with the transformer in the loft. (Including a switched 3A fuse)
It is a simple affair - two wires to the fan from the transformer.
Positive and neutral from the light fitting, with a switched positive supply also from the light fitting.
I have wired the constant positive and negative through the 3A switched fuse.
All was working fine yesterday, you pull the light cord in the bathroom, the light and fan comes on. After the fans time out period it turned off.
Today however, with no lights on, the fan is constantly on!
I have checked the wiring, no shorts etc, but strangely the light on the transformer which is normally on when the fan is working is not illuminated, despite the fan working.
I have checked with a meter that the switched positive supply is off and that there is a constant positive 240v at the correct terminals and a neutral at the correct terminals on the transformer.
When I turn off the switched fuse though there is a very small voltage leak (I think it was about 6v) through the switched positive supply, but obviously the fan does not come on now because I have isolated the main feed.
What is going on - is this a fault with the transformer or with my wiring?
If it's my wiring then why was it working fine yesterday?
(I assume the switched fuse does not need to be earthed because the transformer has no earth - if it did I would have to run a seperate cable up to the fuse just as an earth)
Any help or suggestions appreciated.
Thanks,
Thanks,
