Yes thankyou i'm a 24 year old single mum who works part time how can i afford an engineer. There are no fault lights on just the power light if there was fault lights i might have a little inclin of the problem.
Can you explain a little more what does (or doesnt!) happen? With this type of boiler it should fire up on demand for hot water, i.e. when the tap is turned on the boiler detects the flow of water and fires to heat the water.
