I have a couple of problems with this boiler. The first one is the domestic hot water not heating between 6:30 am and 10:30 pm. Nothing to do with the timer. I suspect its the mains water pressure being too low so the flow is insufficiently high to trigger a faulty pressure sensing mechanism. So it probably needs a new DHW diaphragm or a bit of a clean.
The other problem is that when the hot water does come on it heats up the water in the central heating system. The central heating pump doesn't come on so it doesn't seem to be a logical/electronic problem. Is this normal heat conduction though the boiler components or is there likely to be a leak somewhere?
