If you're going to use a 4P MCB, that's four modules in your CU that could have been used for SP MCBs to give four radial circuits of 20A each. Total permissible load 80A, as opposed to the 40A your circuit arrangement would give.
Why in the world would you want to mess around with redesigning the ring final when multiple radials are clearly a better option? Aside from a given amount of CU space offering more current, there's also the fact that it's easier to isolate a small portion of the installation, and any fault will be confined to a minimum number of outlets.
