This morning, just after plugging in the iron, the power went off on a good percentage of the house sockets. The RCD in the CU has tripped, and attempts to reset it fail. The switch just seems to be "floppy" (as opposed to clicking back into the on position and tripping again).
Do RCD's fail? And if so, are they easy enough to replace assuming the main switch is off?
The consumer unit is a Hagar (?), the mains sockets are on two rings (other one still fine) and on the "RCD Protected" side of the CU.
Many thanks in advance.
