Morning guys
I've turned my central heating on this morning for the first time in months however it doesnt seem to be working. The boiler (saunier duval f30 classic) fires up for about 15 seconds, then shuts off, this repeats itself every minute or so.
I noticed the temperature on the clock was showing as 65c, the pipe inside the boiler which runs to the internal pump is very hot, the pump is also VERY hot, however the pipe exiting the pump is cold, so the water doesnt appeaer to be leaving the pump. Am i correct in assuming this is a fault with the pump? The central heating was working fine when i switched it off in may.
How do i go about fixing this?
thanks in advance
thanks in advance
