wmachine fault code
28 Sep 2010
Essex
have ariston wmachine have found out it has fault code f15. what is this fault any ideas would be great!!!!!!!!!
What symptoms does the machine have
its also useful to post the
model number
Product number
serial number
error codes can be different between machines from the same manufacturer
If its a standard washing machine F15 = drain problem....pump blocked/faulty, drain hose blocked/kinked, plumbing issue etc.
If its a washer/dryer F15 indicates a faulty dryer relay.
model number
Product number
serial number
Did post details the other day but no info was forth coming-
ariston washingmachine
avxxl105
power,spin and 4 of the option led are flashing and machine does nothing called a company and was told it was fault f15 but unless we got engineer out they wouldnt say what the code meant!
thanks for looking
I did reply to your other post. You have a pcb fault need a new pcb cost 90.00 plus smart card and reader.
