Hello all,
I'm new here so be gentle!
I've got a bit of damp on an external wall in my living room an after extensive research I have decided to try and deal with this small amount of damp myself, using an injected 'safe' chemical called dryzone.
The damp inquestion is in a solid brick wall which is external and I have taken steps to reduce possible causes such as 're-pointing' a down pipe to be more central to a drain, doing some pointing ont he external wall and removing a lot of debris which was leaning up agains the wall, both externally and under the floor boards.
I have (as you will see in the photo) chopped off a fair bit of plaster and want to fix the problem before I decorate.
As far as I can see there is no DPC sheeting, as the house is from the 1930's. The method used for DPC in this house appears to be a layer of blue bricks which (again after a bit of research) are possibly the type which resist water absorbsion.
Could anyone confirm from the photos that there is no dpc plastic layer in use, as i dont want to drill any holes which might worsen the rising damp problem.
Here are the photos
Any input very welcome. Thank you very much.
Here are the photos
