Hi all
I hope that this is a simple problem. I just tried to turn my central heating on this morning, but the boiler doesn't fire up when the timer is advanced.
The boiler fires up for hot water heating OK, and the 3-way valve seems to work when the CH timer is advanced to 'on' - I can hear the whir of the 3-way valve moving and if both water and CH are set to 'on' then I feel warm water reaching the radiators. The room thermostat is clicking OK.
The red light on the timer comes on when CH is advanced to 'on', but the boiler isn't fed any mains (i.e. the 'Mains on' light on the boiler isn't lit).
I've tried to check the room thermostat with a digital multimeter and while I'm not quite sure what I'm testing for, the Live (1) to Neutral (3) changes value when the dial is turned and clicked...
Here's the gear:
Boiler: Worcester Danesmoor 15/19
Timer: Drayton LP241
Room thermostat: Honeywell T40 (basic dial type)
Many thanks for any suggestions of what to look for.
Cheers
Paul
Here's the gear:
Cheers
Paul
