Wired a heating system using 2 zone valves & 2 stats(one for upstairs & one for down), boiler is a condensing boiler.
Customer has now decided to have underfloor heating in the kitchen & a manifold has been fitted. Ive put a thermostat cable from the wiring centre for a room stat in the kitchen. On the manifold is a pipe stat. Does this have to be wired aswell ? What does this do ?
Also, if the stats in the other part of the house are calling for heat & the kitchen stat isnt, the underfloor pump on the manifold would run with its zone valve closed, would this be ok?
