help and advice muchly needed
17 Oct 2010
Cornwall
I am considering converting part of a room upstairs into a toilet - I'm aware that it would need some kind of extraction fan, however there is no loft space available as there is a flat above, a sold granite wall and two partition walls ...
I'm wondering whether I could get away with putting an extractor fan in the partition wall ? - this would lead into the room next door to the toilet..
or would I have to drill through the granite wall to fit an extraction fan in?
or is there any other ceiling fan that I can use which doesn't involve the use of a loft - help and advice muchly appreciated.
why do you want to vent your dogey curry from last night in to the next room use a core drill to drill the hole out sorted
I certainly wouldn't want to extract my smells into a neighbouring room. I'd rather leave them in the new toilet. If you are completely boxed in with no loft, what about following the ducting out the same way as the waste pipe.
I assume you've thought about your waste pipe, which I can only gather runs through the other bedroom.
Hi Hwilson26
Yes a question on soil pipe, Will you have anouth fall?, a few years ago I removed a soil pipe the previouse home owner had put in for a ensuite between two bedrooms, it had no fall, was laying on downstairs ceiling ,when I pulled 3 mtre length of soil pipe out it was bunged up, and looked like one dirty great sausage what a stink and mess all over the yard, plus prat had vented into roof space. Think carefully about how you will do this job.
I recall years ago, on Tomorrows World (BBC1), inventor Bob Symes showed a fan which extracted direct from the toilet pan - I don't recall where it extracted to though
Not sure if anything is on the market, but googling may help
