Your Thoughts Please
11 Nov 2010
Kent
Hi. I have recently had a couple of radiators moved and a new CH pump fitted.The system before the upgrades worked fine with all radiators getting hot albeit, some of them slowly !
Since the upgrades we now have a raidiator in an en suite bathroom which is stone cold ??
We have a pressurised system and have 4 zones basically. A zone which is for the bathroom rads and is always on. A zone for the upstairs heating (2 floors), a zone for the downstairs heating and one for the HW.
I have tried the following :
1. Turned off the rads other than the one that is cold on the bathroom loop to tray and force everything through the en suite rad but nothing happens !
2. Repeated 1 but for the upstairs heating loop and still no joy.
3. Bled the rad but no air in it just the cold water coming out.
I have been told that this can only be air but whay has it not fixed it when i have forced everything through the 1 rad ??
For the record, the plumber put some chemicals in but could only do it via taking the top off a pressure release valve i think, but not 100% Could that have affect it ??
Any ideas ??Thanks
Lee
Thanks for the replies. I have read the links but not sure exactly where to start. I have bled an ice cream tubs worth of water out of the radiator (2l) whilst the other 2 rads on this loop were shut down altogether. There was quite a flow of water but all cold. It did start to warm a little at the flow end of the rad at the valve but as soon as i closed the bleed valve the rad remained cold as did the flow valve. I am starting to wonder if the return pipe i sblocked maybe and nece the water not getting through the rad.
Does that sound possible or do you have any other advice.
Regards
Lee
Are you sure its been connected to the flow and return ? (I.E. not both connected to flow)
The radiator in question has been untouched. It is just a case of it has not got hot since he re-filled the system. Like i said, i have bled it this morning for 2l worth of water but put the bleed screw back in and it don't get hot but it did before the system was drained and 2 new rads put in downstairs.
I will let you know the outcome once the guy has been back !
