Hi all,
Our newly purchased house (modern construction, 5 years old) has an odd problem. Potterton Performa 28E system boiler, fitted with Myson room thermostat and 2-channel timer, feeding rads and a megaflo hot water tank. Timer controls 2x 2-port valves installed below the megaflo (I understand this is a Honeywell S-plan configuration?)
I have observed, on many occasions, the boiler firing up and running despite the timer being switched off. Even more annoying, with the timer off and the valves closed the radiators aren't getting hot and all generated heat seems to be pretty much wasted.
Is this normal behaviour? It's consuming significant gas, and I can't imagine the cycling is doing the boiler any favours? The system is fitted with a frost thermostat but it's been doing it since the end of summer when temps shouldn't have been an issue.
