Good morning,
I have what seems to be an incredibly old boiler in my house, and I’ve been tearing my hair out trying to figure out the best way to regulate my central heating.
The boiler is a Potterton Flamingo RS 20; I have TRV’s fitted to all the rads, but no other temperature control (i.e. wall mounted thermostat).
On the boiler itself is some form of temperature control, which from the user guide states the following:
THE BOILER THERMOSTAT
The boiler thermostat enables you to control the temperature of the water as it leaves the boiler and it is also used for turning the boiler off and on. The thermostat knob can be set to 0 (OFF), Min, 1, 2, 3, 4 or Max. The graduations Min. to Max. correspond approximately to a temperature range of 55° to 82°C (130° to 180°F).
During the summer months when the boiler is only being used to supply domestic hot water and there is no independent hot water temperature control, the thermostat can be set to position 1 or 2 which will probably be hot enough for bathing or washing up requirements. For washing clothes, a higher setting may be necessary.
In winter months when central heating is required, the thermostat knob can be turned higher but it must be remembered that unless the temperature of the water in the domestic hot water tank is independently controlled the stored hot water could be at a temperature that could scald.
(I have what I think is an immersion heater upstairs to control the water and this is on a seperate timer to the one used to control the boiler)
So what I read from that is that the higher the setting, the hotter the water becomes before reaching the radiators? However, I would say the difference is minimal and I find the only difference between 1 and 4 is the amount of times the boiler ticks over and fires up whilst on. Is this how it should work?
So on to the TRV’s….I am confused about how these actually work? If you say set the TRV to 4, does the rads stay at this constant temperature whilst the heating is turned on? Or do the TRV’s work on the basis of the room temperature reaching level 4, and then cool/heat accordingly to maintain this temperature?
I ask the question because I have previously had all the trv’s set to MAX, and the temperature of every RAD stays constant whilst the heating is on. However, when I have then turned them all down to 4, I find that some radiators maintain a constant temperature and others seem to cool very quickly, heating up occasionally whilst the heating is switched on (generally when the boiler fires up, the rads get hot and then they cool down again).
What I would really like to know is, based on the rather outdated system I have, what would be the best way to use the system when the heating is on for long periods (e.g. on all day). Should the boiler temperature be set low and the TRV’s high? Should I keep the boiler temp on high and regulate the temperature through the TRV’s? Or would a combination of the 2 be better?
Any advice would be greatly appreciated.
