Looking to buy/repair the following.
My handle turns 360 degrees and won't operate the door mechanism - can it be repaired or must I replace?
If so can anyone advise on the best place to buy from - i am Stoke area.
Millenco 3 Hook 2 Anti-Lift Bolt 2 Roller upvc Door Lock
Multipoint upvc Door Lock Specification:
Spindle to key: 117mm
Backset 35mm
Lever Lever or Lever Pad locking operation
3 hook
2 roller cam
2 anti lift bolts
1 centre latch
The mechanism can be handed LH or RH by removing the centre latch and turning it.
The face plate is 16mm wide in flat stainless steel, silver in colour.
Click here to view "Backset" and "Spindle to key" measurements
Centre of top spindle hole to centre of top hook gearbox: 616mm
Centre of top spindle hole to centre of bottom hook gearbox: 686mm
Backset 35mm
3 hook
2 roller cam
2 anti lift bolts
1 centre latch
