Heatline Vizo 24 not working as red light keep flashing!!!
26 Jun 2010
Liverpool
Heatline Vizo 24 not working as red light keep flashing!!! see attachment photo.
The boiler seems working prefectly fine when the fan starts running, then sparking commence, afterward burner ignite. BUT after about 5 seconds it shut off, and the red LED light starts to flash. The red LED light Flashing which means "Flashing Flames or Gas Failure" as stated in the manual. And i tried to switch to the "O" position which will restart or reset it. BUT same problem occurred. This happened about 10 times since it was discovered. But everytime the fault occurred, it will work the day after. BUT this time does not work at all. PLEASE HELP!!!!!!!!
The condesate outlet pipe is either blocked or more likely frozen!
An Agile three minute reply!
Tony Glazier
Tony Glazier
Hi Tony, nice to see you replied again, i had poured hot water over it, but fault occur, by the way, the boiler only 6 months old. No problem at all in the summer, until end of october as fault started
Tony Glazier
Pour more and pour it slowly...
Tony Glazier
A quick question for you!, do i pour into the pipe or the surface of the pipe?
Condensate drain sensor is wet because outlet is frozen, defrost with hair dryer and insulate the outside bit, pull off condensate pipe and blow down to ensure it is clear then replace. You can then snip the white wire that is attached to the circuit board from the condy sensor and tape it up, the design is to ground flame ionisation current if condensate outlet blocked but this sensor is a nuisance and is only a recent adition to this boiler. Good luck
Thanks for relpying
