I have just replaced an old honeywell thermostat with a new DT90E after reading several threads on this site seemed to be a good bet.
i wired it up using red to A and yellow to B and isolated blue and earth as i read they do not need to be used.
the thermostat is working great with good control of temp except that the central heating system does not go on in the morning at the preset time ie 0520. the heating timer is set to go on at 0520 and off at 2230, the heating goes off at night and does not come on as programmed. the only way at the moment i can get the heating to come on is to turn off the thermostat and then turn on again and the boiler fires up no problem and runs as required during the day to maintain the set temperature.
the dt90e is set to factory defaults and is running on a 3amp circuit if that helps,
if anyone could advise how i can resolve this or if i need to change any settings in installer mode to get the heating to come on as set in the morning that would be great.
thanks mikeke
thanks mikeke
