Hi, old cooker is too small 48cm wide in a house that I have just bought. The old cooker was rated at 9kw and is run on a 6mm cable that goes up the wall under the first floor and back down to the CU. Length of cable is no more than 11M. Back at the fusebox the fuse for this circuit is 45A! I believe this is not to regs so I need to reduce this to a 32A fuse. New cooker has a max load of 9530W. Is this ok (once fuse rating is corrected)or do I need a cable upgrade.
Cheers.
Cheers.
