Hi Guys,
hoping for some quick advice on best practice before I get going on the weekend. Plannign to install 4 double plug sockets into a room I'm refurbing. I will place these 400 - 450mm above the floor (to the bottom of the socket).
What's the best way to cut/chase these int othe wall? I don't have a chasing machine, but have the hammer drill with sds chisel bits. Can I simply trace the outline of the socket backing onto the brickwork and then use a 40mm wide chisel bit or is it best advised to use the old angle grinder for the edges and then chisel out the middle?
Also how wide and best to chisel out the chasing downwards into the floor boards for the cabling?
Any advice would be a great help.
thanks
thanks
