HI, please excuse me if this comes across as a weird question, but boilers, etc., definitely aren't my forte
Got an Alpha SY24. Had a pressure gauge and the PRV replaced about 1 week ago. Found that the expansion vessel is also knackered, and needs replacing. Engineer is coming next weekend to do so. To prevent too much venting, he set the boiler thermostat to 4 so that it cycles down when the gauge gets to around 2.3 (with the CH on). He initally set the cold pressure to 1 bar.
Even with the gauge only reaching 2.3, there was still some water coming out of the PRV, outside. The gauge has gradually falled over the days to around 0.5, although in the last day I haven't noticed any water from the PRV - but I put this mainly down to us only using ther CH very sparingly, given the mild weather here in our part of Sussex.
Probably stupid of me, but to make sure that the boiler didn't cut out due to low pressure (as I may be away for a few days next week, and the wife is even worse than me with the CH), I gently let some water in via the fill loop to get the cold pressure to 0.75 bar.
Had the CH on for a little while earlier, and I'm concerned that there was no venting evident. The gauge got up to around 2.25 max.
Could just be that was only observing venting when the boiler was on longer - but, could the PRV become blocked. Would this require a lot of debris ? I'm hoping that if it is, the fact that the boiler keeps cycling down will prevent any damage to the system.
