I would dearly like to hear from as many as possible, who have experienced similar problems to mine.
I have done lots of temperature measurements and adjustments, also swapping TRV heads around to compare. My conclusion is that these valves are just not up to the mark, in 2 unconnected ways.
The main problem is that they shut down the water flow at too low a temperature. The spec. says max. setting air temperature should be 28deg. But in practice, it is between 19deg. And 21deg, depending on the outside air, and boiler water temperatures. Not warm enough for sitting around comfortably.
The other irritating problem is noise generated by both types of valve. In the lockshields, noticeable when they are adjusted only slightly open. In the TRVs, when they are closing. Both types of noise are supposed to be eliminated by adjusting the automatic bypass valve to a low differential pressure. However, even set to minimum, the noise is still there – to a really annoying level on two radiators.
With thanks in advance for your help – and any recommendations for good replacements would be most acceptable!
